Hello All,
Does someone knows a possible reason why AXP 209 on some boards are failing?
That will result to an error message "Failed to set core voltage! Can't set CPU frequency".
After that we cannot probe the i2c bus address of the AXP209 anymore.
Hope someone can share some insights.
U-Boot SPL 2015.10-rc5-gc387326-dirty (May 19 2016 - 19:02:38)
DRAM: 1024 MiB
Card did not respond to voltage select!
U-Boot 2015.10-rc5-gc387326-dirty (May 19 2016 - 19:02:38 +0800) Allwinner Techy
CPU:   Allwinner A20 (SUN7I)
I2C:   ready
DRAM:  1 GiB
MMC:   Card did not respond to voltage select!
SUNXI SD/MMC: 1, SUNXI SD/MMC: 0 (eMMC)
In:    serial
Out:   serial
Err:   serial
SCSI:  SUNXI SCSI INIT
AHCI PHY power up failed.
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 2 USB Device(s) found
Thanks in advance...
