dynamo Posted May 14, 2021 Posted May 14, 2021 Hi, I'm new to armbian, running armbian focal on an ODROID HC4. I'm trying to setup ZFS but when I install the zfs packages it is failing to build the kernel module. I checked the release notes for ZFS 2.0.1 and it should support 5.10 kernels? Any pointers are appreciated. root@odroid:~# uname -a Linux odroid 5.10.34-meson64 #21.05.1 SMP PREEMPT Thu May 6 21:24:14 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux root@odroid:~# dpkg -l | grep zfs ii libzfs4linux 2.0.1-1 arm64 OpenZFS filesystem library for Linux ii zfs-auto-snapshot 1.2.4-2 all ZFS automatic snapshot service ii zfs-dkms 2.0.1-1 all OpenZFS filesystem kernel modules for Linux ii zfsutils-linux 2.0.1-1 arm64 command-line tools to manage OpenZFS filesystems root@odroid:~# zfs -V zfs-2.0.1-1 zfs_version_kernel() failed: No such file or directory root@odroid:~# modprobe zfs modprobe: FATAL: Module zfs not found in directory /lib/modules/5.10.34-meson64 Thanks.
Solution dynamo Posted May 14, 2021 Author Solution Posted May 14, 2021 Never mind, I found out the armbian-config utility didn't install the kernel headers when I selected them. I had to manually install them. That fixed it.
