HoneyCloak Posted May 31, 2021 Posted May 31, 2021 I recently bought an Odroid HC4 to use as NAS. I then installed the latest Armbian (kernel 5.10, so pretty current one) and zfs-dkms (2.0.3-1, from backports - so again should be pretty current). I can now create ZFS pools from my attached HDDs (currently just one - may mirror later). Great... except I want them encrypted and performance is BAD. Like 40 to 70MB/s when copying via Samba (depending on which cypher I create the dataset with, no compression or deduplication) and CPU pegged at 100% bad. I was honestly surprised by this, considering the S905X3 is supposed to have hardware crypto acceleration (and cryptsetup benchmark shows results more in line with what I'd expect), so as a last ditch attempt I used luks to encrypt the drive and created the ZFS pool on top of the mapped block device. Now Samba copies go at gigbit speed and cpu usage is ~70%. Is there a reason for such massive discrepancy? I'd really like to keep ZFS as close to the metal as possible, but I cannot give away so much performance - anything else I can attempt to fix? I could find some reports of similar performance issues with ZFS, but those should have been fixed by now - is this something different (maybe the fix was specific to AES-NI and x86?) pr did the fix not make it to Armbian's ZFS packages? For reference: cryptsetup benchmark # Tests are approximate using memory only (no storage IO). PBKDF2-sha1 477493 iterations per second for 256-bit key PBKDF2-sha256 878204 iterations per second for 256-bit key PBKDF2-sha512 447344 iterations per second for 256-bit key PBKDF2-ripemd160 305529 iterations per second for 256-bit key PBKDF2-whirlpool 114573 iterations per second for 256-bit key argon2i 4 iterations, 477274 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) argon2id 4 iterations, 479560 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) # Algorithm | Key | Encryption | Decryption aes-cbc 128b 535.0 MiB/s 591.1 MiB/s serpent-cbc 128b 44.9 MiB/s 49.5 MiB/s twofish-cbc 128b 70.0 MiB/s 74.9 MiB/s aes-cbc 256b 464.2 MiB/s 547.2 MiB/s serpent-cbc 256b 44.9 MiB/s 49.5 MiB/s twofish-cbc 256b 70.0 MiB/s 74.8 MiB/s aes-xts 256b 566.8 MiB/s 566.2 MiB/s serpent-xts 256b 46.3 MiB/s 49.9 MiB/s twofish-xts 256b 73.6 MiB/s 76.0 MiB/s aes-xts 512b 526.9 MiB/s 526.4 MiB/s serpent-xts 512b 46.3 MiB/s 49.9 MiB/s twofish-xts 512b 73.6 MiB/s 76.0 MiB/s lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 2.7T 0 disk └─sda.luks 251:0 0 2.7T 0 crypt zpool status tank0 pool: tank0 state: ONLINE config: NAME STATE READ WRITE CKSUM tank0 ONLINE 0 0 0 sda.luks ONLINE 0 0 0 errors: No known data errors sync; dd if=/dev/zero of=/tank0/testfile bs=1M count=1024; sync 1024+0 records in 1024+0 records out 1073741824 bytes (1.1 GB, 1.0 GiB) copied, 7.21141 s, 149 MB/s
