To enable the armbianmonitor to show information on the running system on the serial console, I used to have a custom startup script, called from /etc/rc.local. After some time, I thought it was more neat to have this automatically started (and stopped) for login sessions that are started on serial consoles/terminals.
This lead (led?) me to the following systemd unit file:
[Unit]
Description=armbianmonitor on ttyS2
Requires=serial-getty@ttyS2.service
After=serial-getty@ttyS2.service
After=getty.target
BindsTo=serial-getty@ttyS2.service
[Service]
Type=idle
ExecStartPre=-/bin/sleep 10
ExecStart=/usr/bin/armbianmonitor -m
TTYPath=/dev/ttyS2
StandardInput=null
StandardOutput=tty
StandardError=syslog
KillSignal=SIGKILL
SendSIGHUP=yes
[Install]
WantedBy=serial-getty@ttyS2.service
File goes into /usr/lib/systemd/system/armbianmonitor@ttyS2.service. To 'activate' it, perform the following after creating the file at the specified location:
sudo systemctl daemon-reload
sudo systemctl enable armbianmonitor@ttyS2
sudo systemctl stop armbianmonitor@ttyS2
sudo systemctl start armbianmonitor@ttyS2
This is currently working for me on OrangePi Zero, NanoPi R2S, Helios4 (@ttyS0) and Helios64.
If you do not have serial-getty services started on ttyS2 - like in the example unit file - you will need to modify the 'ttyS2' with the serial console matching your situation.
Note that the new armbianmonitor@ttyX service will auto-start when seial-getty@ttyX is started and it will also stop when serial-getty@ttyX is stopped. This is to prevent orphaned armbianmonitors. Fun thing to try is to stop and start serial-getty@ttyX and also see the armbianmonitor service for that tty stop/start in tandem.
Hope this helps anyone out there, it's always nice to have serial output available in case things happen (and they always happen unexpectedly).
Groetjes,
p.s. See below spoiler for auto-adding these unit files based on your currently enabled serial-getty services.
  Reveal hidden contents
