hello,
any idea what kind of issue it might be / how to fix it? after execution reboot cmd it got stuck > error below
Welcome to Armbian 21.05.6 Buster with Linux 4.14.222-odroidxu4
root@odroid-monitor:~# reboot
[   49.378939] reboot: Rest!
U-Boot 2017.05-armbian (May 06 2021 - 18:13:45 +0000) for ODROID-XU4
CPU:   Exynos5422 @ 800 MHz
Model: Odroid XU4 based on EXYNOS5422
Board: Odroid XU4 based on EXYNOS5422
Type:  xu4
DRAM:  2 GiB
Error binding driver 'gpio_exynos': -12
Some drivers failed to bind
initcall sequence be9af240 failed at call 43e18010 (err=-12)
### ERROR ### Please RESET the board ###
the fresh install was done from image
Armbian_21.05.1_Odroidxu4_buster_legacy_4.14.222.img
then i upgrade via apt update; upgrade... so it moved to
and the error reported above started to happen constantly.
I installed again directly Armbian 21.05.6 Buster with Linux 4.14.222-odroidxu4 and it works... strange issue.
No idea why, but on odroid xu4 Armbian 21.05.4 Buster with Linux 4.14.222-odroidxu4
the file /boot/armbianEnv.txt is missing.
boot from UART
## Executing script at 43e00000
** File not found /boot/armbianEnv.txt **
** File not found armbianEnv.txt **
