MastinZgZ Posted July 5, 2021 Posted July 5, 2021 Good morning, I am trying to get a UART to RS485 converter to work on the UART2. The RX Pin is PA1, TX is PA0 and the direction Pin is PA6. How can I activate it in the system, do I have to activate something in the armbianENV.txt? I have overlays = uart2 Some help? Thanks and best regards! Lewis
tparys Posted July 6, 2021 Posted July 6, 2021 I've not tried this, but you might start looking at the 485 specific device tree bindings. If it's possible, you'll almost certainly need to write your own overlay. Also, USB to 485 adapters are only around ~$15 USD on amazon. Unless you need to to use an onboard UART, or want to do it as a project, it may not be worth the time investment. 1
MastinZgZ Posted July 6, 2021 Author Posted July 6, 2021 5 hours ago, tparys said: I've not tried this, but you might start looking at the 485 specific device tree bindings. If it's possible, you'll almost certainly need to write your own overlay. Also, USB to 485 adapters are only around ~$15 USD on amazon. Unless you need to to use an onboard UART, or want to do it as a project, it may not be worth the time investment. Thank you very much, I look at it to see if I get to something. Thank you!
