Good morning,
I have made a board where I have put an RTC DS1307 to a Neo core nanopi.
From what I have been able to see, the system loads some kind of RTC module called sun6i-rtc. this module "occupies" the / dev / rtc0 so when loading the DS1307 it assigns it / dev / rtc1.
Can the sun6i-rtc be disabled in some way?
On the other hand, if I do this command.
hwclock -w -f /dev/rtc1 --verbose
hwclock from util-linux 2.37.154-c2ca2
System Time: 1625751906.401974
Using the rtc interface to the clock.
Last drift adjustment done at 1625751901 seconds after 1969
Last calibration done at 1625751901 seconds after 1969
Hardware clock is on UTC time
Assuming hardware clock is kept in UTC time.
RTC type: 'rtc-ds1307'
Using delay: 0.000000 seconds
missed it - 1625751906.405792 is too far past 1625751906.000000 (0.405792 > 0.001000)
1625751907.000000 is close enough to 1625751907.000000 (0.000000 < 0.002000)
Set RTC to 1625751907 (1625751906 + 1; refsystime = 1625751906.000000)
Setting Hardware Clock to 13:45:07 = 1625751907 seconds since 1969
ioctl(RTC_SET_TIME) was successful.
Not adjusting drift factor because the --update-drift option was not used.
New /etc/adjtime data:
0.000000 1625751906 0.000000
1625751906
UTC
it works correctly, but if I want to read,
hwclock -r -f /dev/rtc1 --verbose
it gives me this error.
System Time: 1625751969.137899
Last drift adjustment done at 1625751906 seconds after 1969
Last calibration done at 1625751906 seconds after 1969
Waiting for clock tick...
ioctl(3, RTC_UIE_ON, 0): Invalid argument
Waiting in loop for time from /dev/rtc1 to change
hwclock: Timed out waiting for time change.
...synchronization failed
the battery is charged, the i2c works well and detects it correctly. Any ideas?
Thanks and best regards.
Armbianmonitor
http://ix.io/3siu
