angrest Posted August 23, 2021 Posted August 23, 2021 (edited) I've installed the latest available version for my board (Armbian_21.05.4_Odroidxu4_buster_legacy_4.14.222) and upgrade the Kernel to 5.4.125 Now, I'm wondering If the watchdog was supposed to work (I do have /dev/watchdog and installed the watchdog package with apt). But it seems there is a problem, here is what I tried: odroidxu4:~:# service watchdog status ● watchdog.service - watchdog daemon Loaded: loaded (/lib/systemd/system/watchdog.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2021-08-23 17:07:20 CEST; 1h 5min ago Process: 2295 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS) Process: 2296 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS) Main PID: 2298 (watchdog) Tasks: 1 (limit: 4447) Memory: 916.0K CGroup: /system.slice/watchdog.service └─2298 /usr/sbin/watchdog Aug 23 17:07:20 odroidxu4 watchdog[2298]: temperature: no sensors to check Aug 23 17:07:20 odroidxu4 watchdog[2298]: no test binary files Aug 23 17:07:20 odroidxu4 watchdog[2298]: no repair binary files Aug 23 17:07:20 odroidxu4 watchdog[2298]: error retry time-out = 60 seconds Aug 23 17:07:20 odroidxu4 watchdog[2298]: repair attempts = 1 Aug 23 17:07:20 odroidxu4 watchdog[2298]: alive=/dev/watchdog heartbeat=[none] to=root no_act=no force=no Aug 23 17:07:20 odroidxu4 watchdog[2298]: cannot set timeout 60 (errno = 22 = 'Invalid argument') Aug 23 17:07:20 odroidxu4 watchdog[2298]: hardware watchdog identity: S3C2410 Watchdog Aug 23 17:07:20 odroidxu4 watchdog[2298]: cannot set scheduler (errno = 1 = 'Operation not permitted') Aug 23 17:07:20 odroidxu4 systemd[1]: Started watchdog daemon. odroidxu4:~:# fuser -v /dev/watchdog USER PID ACCESS COMMAND /dev/watchdog: root 2298 F.... watchdog odroidxu4:~:# dmesg|grep watchdog [ 4.544359] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled odroidxu4:~:# echo "V" >/dev/watchdog zsh: device or resource busy: /dev/watchdog Is the watchdog in general available for this board? What else shall I check? Edited August 23, 2021 by angrest typo
