Netanel Posted September 12, 2021 Posted September 12, 2021 Armbianmonitor: http://ix.io/3yEk Hello, i update my OrangePiZero OS from Linux 5.10.43-sunxi to Linux 5.10.60-sunxi my screen fbtft spi lcd stop working , the screen is black. If there is a solution to this issue I would love to get help, thanks! here my configuration (work on 5.10.43). (Armbianmonitor link of 5.10.43 on top) (Armbianmonitor link of 5.10.60 Attached as a file ) fbtft.dts /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; }; }; fragment@1 { target = <&pio>; __overlay__ { spi1_cs_pins: spi1_cs_pins { pins = "PA13"; function = "gpio_out"; }; opiz_display_pins: opiz_display_pins { pins = "PA7", "PA2", "PA6"; function = "gpio_out"; }; }; }; fragment@2 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; pinctrl-0=<&spi1_pins &spi1_cs_pins>; cs-gpios=<&pio 0 13 1>; opizdisplay: opiz-display@0{ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-0 = <&opiz_display_pins>; spi-max-frequency = <32000000>; rotate = <270>; bgr; fps = <30>; buswidth = <8>; reset-gpios = <&pio 0 7 1>; dc-gpios = <&pio 0 2 0>; led-gpios= <&pio 0 6 0>; debug = <5>; status="okay"; }; }; }; __overrides__ { speed = <&opizdisplay>,"spi-max-frequency:0"; rotate = <&opizdisplay>,"rotate:0"; fps = <&opizdisplay>,"fps:0"; debug = <&opizdisplay>,"debug:0"; }; }; /boot/armbianEnv.txt is: verbosity=1 bootlogo=true console=serial overlay_prefix=sun8i-h3 overlays=analog-codec i2c0 uart1 uart2 user_overlays=fbtft mcp7940 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 1.txt
Netanel Posted December 22, 2021 Author Posted December 22, 2021 Thanks to notro notro I solved the problem, changed the way the screen brightness was controlled. Here is the configuration I have at the moment. reset ---> PA7 led ---> PA6 dc ----> PA2 /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target-path = "/aliases"; __overlay__ { spi1 = "/soc/spi@01c69000"; }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; spidev@0{ status = "disabled"; }; spidev@1{ status = "disabled"; }; }; }; fragment@2 { target = <&pio>; __overlay__ { opiz_display_pins: opiz_display_pins { pins = "PA7", "PA2", "PA6"; function = "gpio_out"; }; }; }; fragment@3 { target = <&spi1>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; opizdisplay: opiz-display@0{ compatible = "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-0 = <&opiz_display_pins>; spi-max-frequency = <8000000>; rotate = <270>; bgr; fps = <30>; buswidth = <8>; reset-gpios = <&pio 0 7 1>; dc-gpios = <&pio 0 2 0>; led-gpios= <&pio 0 6 1>; debug = <3>; status="okay"; }; }; }; __overrides__ { speed = <&opizdisplay>,"spi-max-frequency:0"; rotate = <&opizdisplay>,"rotate:0"; fps = <&opizdisplay>,"fps:0"; debug = <&opizdisplay>,"debug:0"; }; };
