Hello everyone!
I have some strange trouble with OMV - this thing is failing to create sharing directorys with the same error №0 all the time.
I tried clean installation - it didn`t work, I tried different HDD and SSD - the same trouble.
My hardware is NanoPi Air with FriendlyElec NAS dock v1.2. Currently I`m running Armbian buster 5.10.60, OMV was installed by softy, HDD and SSD I`m using are with NTFS FS.
Скрытый текст
Error #0:
OMV\Exception: Failed to create the directory '/srv/dev-disk-by-uuid-E416496416493936/Work/':  in /usr/share/openmediavault/engined/rpc/sharemgmt.inc:326
Stack trace:
#0 [internal function]: Engined\Rpc\ShareMgmt->set(Array, Array)
#1 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#2 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('set', Array, Array)
#3 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('ShareMgmt', 'set', Array, Array, 1)
#4 {main}
I have no clue what is going on with my system because it worked before.  Do you have any ideas how to fix it?
Thanks!
