Orangepi Zero 2 Armbian Focal 5.13.y stuck at "Starting kernel .."
Image used: Armbian_21.08.1_Orangepizero2_focal_edge_5.13.12.img
U-Boot SPL 2021.10-rc1-armbian (Aug 08 2021 - 16:21:36 +0200)
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.5(debug):87311b4-dirty
NOTICE:  BL31: Built : 16:21:30, Aug  8 2021
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a082220, model: OrangePi Zero2
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP305 on RSB
INFO:    PMIC: aldo1 voltage: 3.300V
INFO:    PMIC: aldo2 voltage: 3.300V
INFO:    PMIC: aldo3 voltage: 3.300V
INFO:    PMIC: bldo1 voltage: 1.800V
INFO:    PMIC: dcdcd voltage: 1.500V
INFO:    PMIC: dcdce voltage: 3.300V
INFO:    Changed devicetree to reserve BL31 memory.
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2021.10-rc1-armbian (Aug 08 2021 - 16:21:36 +0200) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: OrangePi Zero2
I2C:   ready
DRAM:  1 GiB
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   phy interface7
eth0: ethernet@5020000
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3202 bytes read in 2 ms (1.5 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
131 bytes read in 1 ms (127.9 KiB/s)
19495 bytes read in 4 ms (4.6 MiB/s)
Failed to load '/boot/dtb/allwinner/overlay/-fixup.scr'
12106416 bytes read in 501 ms (23 MiB/s)
22200328 bytes read in 918 ms (23.1 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=41790000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    12106352 Bytes = 11.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49474000, end 49fffa70 ... OK
   Loading Device Tree to 0000000049406000, end 0000000049473fff ... OK
Starting kernel ...
Edited by izeroo
