djelovsek Posted November 25, 2021 Posted November 25, 2021 Armbianmonitor: http://ix.io/3G3s After the last "sudo apt upgrade" my odroid C4 (meson) doesn't reboot properly anymore. In the system out there are many lines like: "Begin: Running /scripts/local-block ... mdadm: No arrays found in config file or automatically done." and one : "mdadm: error opening /dev/md?*: No such file or directory mdadm: No arrays found in config file or automatically /scripts/local-block/mdadm: 58: /scripts/local-block/mdadm: rm: not found" at the end: "Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev)" it's stuck in initramfs with "ALERT! UUID=<myUUID> does not exist. Dropping to a shell!" When I type "exit" the boot process starts and finishes successfully. screen.pdf
Bongho Lee Posted April 8, 2022 Posted April 8, 2022 I have same problem with Armbian 22.02.1_Orangepi3_focal_current_5.15.25_xfce_desktop.img.
