maknho Posted November 25, 2021 Posted November 25, 2021 Hello, Ihave an Odroid N2 that run with armbian. 1) I can't upgrade armbian-zsh_21.08.6_all.deb The output of apt upgrade is : (Lecture de la base de données... 133099 fichiers et répertoires déjà installés.) Préparation du dépaquetage de .../armbian-zsh_21.08.6_all.deb ... Dépaquetage de armbian-zsh (21.08.6) sur (21.08.5) ... dpkg: erreur de traitement de l'archive /var/cache/apt/archives/armbian-zsh_21.08.6_all.deb (--unpack) : impossible d'ouvrir « /etc/oh-my-zsh/plugins/osx/README.md.dpkg-new »: Aucun fichier ou dossier de ce type Des erreurs ont été rencontrées pendant l'exécution : /var/cache/apt/archives/armbian-zsh_21.08.6_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) 2) Output of armbianmonitor -u : http://ix.io/3G3N Any tips or things to do. Thanks by advance
tomislav177 Posted November 26, 2021 Posted November 26, 2021 I have the samo error on Odroid xu4 Armbian 21.08.6 Buster with Linux 5.4.160-odroidxu4 odroidxu4:~:# apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-zsh 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/3013 kB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 58064 files and directories currently installed.) Preparing to unpack .../armbian-zsh_21.08.6_all.deb ... Unpacking armbian-zsh (21.08.6) over (21.08.5) ... dpkg: error processing archive /var/cache/apt/archives/armbian-zsh_21.08.6_all.deb (--unpack): unable to open '/etc/oh-my-zsh/plugins/osx/README.md.dpkg-new': No such file or directory cp: cannot create directory '/home/server/.oh-my-zsh': No such file or directory cp: cannot create regular file '/home/server/.zshrc': No such file or directory chown: cannot access '/home/server/.oh-my-zsh': No such file or directory chown: cannot access '/home/server/.zshrc': No such file or directory Errors were encountered while processing: /var/cache/apt/archives/armbian-zsh_21.08.6_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
maknho Posted November 27, 2021 Author Posted November 27, 2021 Hello I solved these problem with a reinstall (see there where I repost these question : )
