arneee Posted November 25, 2021 Posted November 25, 2021 Hi, not sure if this is the right place to ask, but I just dug up an old banana pi m2plus (with on board wifi) and flashed the latest Armbian_21.08.1_Bananapim2plus_bullseye_current_5.10.60 on a class 10 samsung evo micro sd. When booting for the first time I had a monitor, keyboard and LAN attached and successfully set up users with the wizard and apt upgrade the system. Now I tried to set up wifi with "nmtui-connect SSID " after this guide: https://docs.armbian.com/User-Guide_Getting-Started/ where SSID is the SSID of my network, but I get "No such connection 'SSID' " and I can only confirm. If I open the networkmanager with it looks like this: │ │Wired ↑ │ <Deactivate> │ │ │ * Wired connection 1 ▒ │ │ │ │ ▒ │ │ … │ │ ▮ │ │ │ │ ↓ │ <Quit> $ sudo iwconfig lo no wireless extensions. eth0 no wireless extensions. wlan0 IEEE 802.11 ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off I reflashed the image with the same result. sudo armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/3G4v Could it be a hardware problem? Thankful for any suggestions on how to investigate.
Solution arneee Posted November 26, 2021 Author Solution Posted November 26, 2021 After a third clean installation, I was able to solve the problem by following instructions on this thread: https://forum-raspberrypi.de/forum/thread/36801-wlan-nach-2-tagen-ausgefallen/?pageNo=2
