I'm trying to get a new board working using Armbian.
I'm currently working from my GIT repo so I cloned armbian/build and u-boot/u-boot
I added them to the compile.sh script by using userpatches/lib.conf overrides.
I added the DTS file of the board, defconfig and modified the Makefile as it can be seen on this commit
On the board config side, I set:
BOOTCONFIG="fly_gemini_defconfig"
The image is built successfully but the board doesn't boot because the DTB file isn't present in /boot/dtb/allwinner/sun50i-h5-fly-gemini.dtb
I looked in output/debug files but I didn't found any error
What did I miss ?
Any hint to point me where to look or what step I need to do is welcome.
Thanks !
I finally found the solution: the DTB is also compiled by the kernel so the DTS file need also to be there.
I'm going to use patching as it seems to be finally a better route than cloning these repos.
