remlei Posted December 31, 2021 Posted December 31, 2021 (edited) TV Box Status Information Template Version 1.0 TV Box Name: MXQ Pro 4k 5G (fake 16GB RAM/128GB ROM) CPU: Allwinner H3 Armbian build file name: Armbian_21.08.1_Orangepipcplus_focal_current_5.10.60.img.xz / Armbian_21.08.1_Orangepipcplus_buster_current_5.10.60.img.xz (both works) DTB file used: <none> Kernel Version: 5.10.60 Distribution Installed: focal and buster Working Ethernet (Yes/No): yes Max Ethernet Speed that works (100/1000): 100M Does wifi work (Yes/No): yes Does bluetooth work (Yes/No): not available Does HDMI audio work (Yes/No): yes Additional Comments (provide any additional information you feel is important): all other functionalities for Orange Pi PC Plus is not available (eg OTG function of USB and no GPIO). You can also run "nand-sata-install" command to install armbian to emmc, works fine, no issues. Edited December 31, 2021 by remlei 1 Quote
Jason Duhamell Posted June 3, 2022 Posted June 3, 2022 Could you tell me what model was printed on the PCBA's silkscreen? 0 Quote
remlei Posted July 6, 2022 Author Posted July 6, 2022 On 6/3/2022 at 8:27 AM, Jason Duhamell said: Could you tell me what model was printed on the PCBA's silkscreen? Q44_V4.0_20200602 0 Quote
abhinavpra Posted November 3, 2022 Posted November 3, 2022 Can you share the steps or guide which you used @Jason Duhamell @remlei if you were able to get armbian working on this tv box ( MXQ Pro 4k 5G) 0 Quote
remlei Posted December 5, 2022 Author Posted December 5, 2022 @abhinavpra I used Orange Pi PC Plus image but you should try Orange Pi PC image first and see if it can boot, if it does you can try the Plus image and do a nand-sata-install in terminal to install armbian to emmc, though there are likely chance that it may not be able to detect the internal storage since newer mxq box with allwinner h3 contains emcp. 0 Quote
marcos antonio pereira junior Posted November 16, 2023 Posted November 16, 2023 how did you manage to make the wifi work for me it doesn't appear 0 Quote
forart.it Posted April 1, 2025 Posted April 1, 2025 Hi everyone, I do have troubles with wifi too... any suggestion ? 0 Quote
