voltagex Posted January 11, 2022 Posted January 11, 2022 Looks like a missing gmp dependency? From armbian/build 5bfa587727f29a072b21ca936ab9f00ffdfbd502 == kernel == In file included from /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/gcc-plugin.h:28, from scripts/gcc-plugins/gcc-common.h:7, from scripts/gcc-plugins/randomize_layout_plugin.c:19: /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/system.h:687:10: fatal error: gmp.h: No such file or directory 687 | #include <gmp.h> | ^~~~~~~ compilation terminated. In file included from /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/gcc-plugin.h:28, from scripts/gcc-plugins/gcc-common.h:7, from scripts/gcc-plugins/structleak_plugin.c:32: /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/system.h:687:10: fatal error: gmp.h: No such file or directory 687 | #include <gmp.h> | ^~~~~~~ In file included from /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/gcc-plugin.h:28, from scripts/gcc-plugins/gcc-common.h:7, from scripts/gcc-plugins/latent_entropy_plugin.c:78: /root/armbian/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin/../lib/gcc/aarch64-linux-gnu/8.3.0/plugin/include/system.h:687:10: fatal error: gmp.h: No such file or directory 687 | #include <gmp.h> | ^~~~~~~ compilation terminated. compilation terminated. make[2]: *** [scripts/gcc-plugins/Makefile:47: scripts/gcc-plugins/randomize_layout_plugin.so] Error 1 make[2]: *** Waiting for unfinished jobs.... make[2]: *** [scripts/gcc-plugins/Makefile:47: scripts/gcc-plugins/structleak_plugin.so] Error 1 make[2]: *** [scripts/gcc-plugins/Makefile:47: scripts/gcc-plugins/latent_entropy_plugin.so] Error 1 make[1]: *** [scripts/Makefile.build:497: scripts/gcc-plugins] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [Makefile:1199: scripts] Error 2 output.zip
voltagex Posted January 11, 2022 Author Posted January 11, 2022 ./compile.sh docker BOARD=espressobin BRANCH=current RELEASE=bullseye BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img works, but there is an issue if KERNEL_CONFIGURE=yes is set
