ProstoUser Posted January 28, 2022 Posted January 28, 2022 Hi all. In this topic I will show, how to make work USB sound card with Orange Pi. I did not found similar information, so I decided to put this info into a forum. At the moment, I have working mocp from root user, which able to play mp3 and online radio. I am not sure if all steps are necessary. So if You know a shorter version of this, please post a reply. Lets begin. 1. Insert USB sound card, Boot Orange Pi, and login via SSH. Цитата mocp output: Running the server... Trying JACK... Trying ALSA... Trying OSS... FATAL_ERROR: No valid sound driver! FATAL_ERROR: Server exited! alsamixer not work without arguments ( It may print something like: cannot open mixer: No such file or directory ). But this works: alsamixer -c 1 2. I am not sure if this step is necessary, but I installed apt install pulseaudio ( https://wiki.debian.org/PulseAudio ) 3. amixer able to find usb sound card 4. lsmod | grep snd_usb_audio ( just making sure that snd_usb_audio is loaded ) 5. We need to add our user ( root and other if You want ) to audio group usermod -a -G audio root 6. Setting the default device https://www.alsa-project.org/wiki/Setting_the_default_device Цитата Find your desired card with: cat /proc/asound/cards and then create /etc/asound.conf with following: defaults.pcm.card 1 defaults.ctl.card 1 Replace "1" with number of your card determined above. and reboot the system. Then login again via SSH. 7. Type in console modprobe snd-pcm-oss Then add to /etc/modules ( from new line ) snd-pcm-oss or to /etc/rc.local modprobe snd-pcm-oss 8. At this moment You should have /dev/dsp or /dev/dsp1 You can type ln -s /dev/dsp1 /dev/dsp to make available sound card for cmus ( otherwise cmus answer with error: opening audio device: No such device ) You can also, if You want, add to /etc/rc.local ln -s /dev/dsp1 /dev/dsp by doing this, it will add a link from /dev/dsp1 to /dev/dsp during boot process At this moment, your mocp should play. 9. Next step is copy config from /usr/share/doc/moc/examples/config.example to ~./.moc/config and then edit this file to this proposed setting: Цитата OSSDevice = /dev/dsp1 ( or whatever it is, it can be also a /dev/dsp ) InputBuffer = 1024 OutputBuffer = 1024 Prebuffering = 170 Save and close the file. Now you can run mocp and play some file or radio. Also, from this moment alsamixer works without arguments.
