5.15.25 breaks SPI on NanoPi Neo and does not create /dev/spidev0.0
Go to solution Solved by Falcounet,
Am 12.5.2022 um 16:09 schrieb going:
This will update (install with replacement) your kernel and dtb.
Don't do anything with the 5.17 kernel. It works and will be a backup in case something goes wrong in the future.
You can switch to it by simply correcting the links.
"current" 5.15.35 / 22.05.0 works without any problems on my Nano 😀
An apt-get upgrade want's to upgrade linux-image-edge-sunxi. Should that be done? Or does it upgrade and switch again to 5.17 as active kernel?
