hei-pa Posted April 16, 2022 Posted April 16, 2022 Hi, i need a gpio to trigger a key stroke. I had an raspberry pi zero and this worked for setting up an gpio to trigger a key stroke. For some reason I am not able to port this to my orangepi 3 lts H6 board. I think there is some confusion because there are two pin-controller? Do I have to set the right one anywhere? I thought the setting will be listed here like the raspberry did root@orangepi3-lts:~# cat /sys/kernel/debug/gpio gpiochip1: GPIOs 0-255, parent: platform/300b000.pinctrl, 300b000.pinctrl: gpio-79 ( |usb0_id_det ) in hi gpio-102 ( |gmac-3v3 ) out hi gpio-110 ( |PHY reset ) out hi ACTIVE LOW gpio-166 ( |cd ) in lo IRQ ACTIVE LOW gpio-226 ( |ddc-en ) out hi gpio-231 ( |vcc33-wifi ) out hi gpiochip0: GPIOs 352-415, parent: platform/7022000.pinctrl, 7022000.pinctrl: gpio-356 ( |red-led ) out lo gpio-359 ( |green-led ) out hi gpio-387 ( |reset ) out hi ACTIVE LOW Here's my try using gpio "PD21" aka 117 for an active low input (bias-pull-up is not active ?!) /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; fragment@0 { target = <&pio>; __overlay__ { gpio_keys: gpio_keys { pins = "PD21"; function = "gpio_in"; bias-pull-up; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&gpio_keys>; keypad: photobox { compatible = "gpio-keys"; #address-cells = <1>; #size-cells = <0>; autorepeat; button@117 { label = "KEY_R"; linux,code = <19>; // r gpios = <&pio 117 1>; }; }; }; }; }; What does `pinctrl-0 = <&gpio_keys>;` mean? Is there an automatic mapping to the right pinctrl? I have seen that the gpio pins eg. PD21 are represented as `gpios = <&pio 3 21 0>` here ... but it doesn't help either ^ ^ - 21 as pin offset - 3 multiplicator (A=0, B=1, C=2, D=3 ?) Maybe I need to build with "CONFIG_INPUT_MATRIXKMAP" ? CONFIG_INPUT=y CONFIG_INPUT_LEDS=y CONFIG_INPUT_FF_MEMLESS=m # CONFIG_INPUT_SPARSEKMAP is not set # CONFIG_INPUT_MATRIXKMAP is not set
