Glen Lovsin Posted April 16, 2022 Posted April 16, 2022 Attempted to work with both latest Bullseye and Focal images for OrangePi R1 but in both instances got the following message: E: Failed to fetch https://xogium.performanceservers.nl/apt/pool/focal-utils/w/wpa/hostapd_2.10-6~armbian22.02.3+1_armhf.deb Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 104.36.81.15 443] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Pasted here (duplicate of above) as well valid 90d. http://paste.debian.net/plain/1238152
Solution Glen Lovsin Posted April 16, 2022 Author Solution Posted April 16, 2022 Disregard. Set clock (time zone) in armbian-config. sudo apt update and then the package installed. Never encountered this time issue on previous releases.
