[CNX-Software] - DIY SBC cases and SBC Case Builder tool based on OpenSCAD
DIY ODROID-H2 SBC case
Since you can’t always rely on single board computer (SBC) vendors to provide a case to match your needs, some went the DIY route. William Tarreau designed some laser-cut enclosures with Inkscape for various SBCs, while hominoids went a step further by developing the “SBC Case Builder” tool to automatically generate various types of 3D printable enclosures using OpenSCAD. William designed five similar enclosures for Khadas VIM3/VIM3L, FriendlyELEC NanoPi Fire3, SolidRun Clearfog Base networking SBC, Libre Computer AML-S805X-AC (aka “La Frite”), and AAEON UP Board. All cases are available in Inkscape SVG format, and William accepts contributions for other boards. You’ll need a laser engraver or CNC router to cut out those enclosures. Hominoids’ SBC Case Builder project attempt to automatize enclosure generation for SBCs using SBC Model Framework written in OpenSCAD. Work has focused on ODROID boards so far, but it should work for other vendors too. The parameters [...]
The post DIY SBC cases and SBC Case Builder tool based on OpenSCAD appeared first on CNX Software - Embedded Systems News.
View the full article
