frogger Posted May 1, 2022 Posted May 1, 2022 TV Box Name (example: TX3 mini): T95M CPU (example: amlogic s905w): amlogic S905X Armbian build file name: Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop DTB file used: meson-gxbb-vega-s95-meta.dtb Kernel Version: 5.9 Distribution Installed (focal, buster, etc): bullseye Working Ethernet (Yes/No): No Max Ethernet Speed that works (100/1000): N/A Does wifi work (Yes/No): Yes Does bluetooth work (Yes/No): No Does HDMI audio work (Yes/No): Yes Additional Comments (provide any additional information you feel is important): I didn't try all the dtbs, as this is enough for me. If I get around to it and find a better one I'll update. 0 Quote
frogger Posted July 8, 2022 Author Posted July 8, 2022 On 4/30/2022 at 11:58 PM, frogger said: MISTAKE. The correct CPU was S905 0 Quote
comm-ents Posted September 26, 2024 Posted September 26, 2024 (edited) It is an older box so I don't see anyone needing this information I was able to boot with the setup above from a microsd, but just installed meson-gxl-s905x-p212.dtb on the EMMC which worked just fine. Edited September 26, 2024 by comm-ents Updated information. 0 Quote
