[Pull Request] - Update only supported repositories
Description
Don't add any packages to CSC repositories (stretch, bionic, ...), but generate index.
Jira reference number AR-1177
How Has This Been Tested?
[ o.k. ] Using config file [ /home/igorp/Devel/build/userpatches/config-example.conf ]
[ o.k. ] Command line: setting REPOSITORY_UPDATE to [ update ]
[ o.k. ] Using user configuration override [ userpatches/lib.config ]
[ warn ] Skipping adding packages (not supported) [ stretch ]
[ warn ] Skipping adding packages (not supported) [ bionic ]
[ o.k. ] Checking and adding to repository buster [ main ]
[ o.k. ] Creating section [ main ]
[ o.k. ] Checking and adding to repository bullseye [ main ]
[ o.k. ] Adding bullseye [ linux-u-boot-odroidn2-current ]
[ o.k. ] Checking and adding to repository focal [ main ]
[ o.k. ] Adding focal [ linux-u-boot-odroidn2-current ]
[ warn ] Skipping adding packages (not supported) [ hirsute ]
[ warn ] Skipping adding packages (not supported) [ impish ]
[ o.k. ] Checking and adding to repository jammy [ main ]
[ o.k. ] Adding jammy [ linux-u-boot-odroidn2-current ]
[ o.k. ] Checking and adding to repository sid [ main ]
[ o.k. ] Adding sid [ linux-u-boot-odroidn2-current ]
[ o.k. ] Cleaning repository [ /home/igorp/Devel/build/output/debs ]
[ o.k. ] List of local repos [ local ]
 * [bullseye-desktop]: Armbian bullseye desktop (packages: 1)
 * [bullseye-utils]: Armbian bullseye utilities (packages: 1)
 * [bullseye]: Armbian main repository (packages: 2)
 * [buster-desktop]: Armbian buster desktop (packages: 1)
 * [buster-utils]: Armbian buster utilities (packages: 1)
 * [buster]: Armbian main repository (packages: 2)
 * [focal-desktop]: Armbian focal desktop (packages: 1)
 * [focal-utils]: Armbian focal utilities (packages: 1)
 * [focal]: Armbian main repository (packages: 2)
 * [jammy-desktop]: Armbian jammy desktop (packages: 1)
 * [jammy-utils]: Armbian jammy utilities (packages: 1)
 * [jammy]: Armbian main repository (packages: 2)
 * [sid-desktop]: Armbian sid desktop (packages: 1)
 * [sid-utils]: Armbian sid utilities (packages: 1)
 * [sid]: Armbian main repository (packages: 2)
 * [stretch-desktop]: Armbian stretch desktop (packages: 1)
 * [stretch-utils]: Armbian stretch utilities (packages: 1)
 * [stretch]: Armbian main repository (packages: 2)
 * [utils]: Armbian utilities (backwards compatibility) (packages: 0)
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [ ] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
