[Pull Request] - Merge rk35xx-edge into rockchip64-edge
Description
Merge rk35xx edge kernel and config into rockchip64 edge kernel. The only difference at this point is that uboot for rk35xx still does not uses mainline uboot
Jira: AR-1180
How Has This Been Tested?
  • [x] Tested on rockpro64
  • [x] Tested on rock-3a
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
