[CNX-Software] - u-blox MAYA-W2 IoT module offers dual-band WiFi 6, Bluetooth LE 5.2, and Zigbee/Thread connectivity
u-blox MAYA-W2
u-blox MAYA-W2 is a tri-radio IoT module supporting dual-band WiFi 6, Bluetooth Low Energy 5.2, and IEEE 802.15.4 (Thread and Zigbee) connectivity based on the NXP IW612 or IW611 chipset introduced last January. The module is offered with a PCB antenna, u.FL connectors, and/or antenna pins, supports up to 600 Mbps link speed, and targets industrial and consumer mass-market applications in industrial automation, smart building & energy management, healthcare, smart home, and more. u-blox MAYA-W2 highlights: Wi-Fi 6 802.11ax dual-band 2.4 and 5 GHz Up to 600 Mbit/s throughput Output power EIRP – 18 dBm Operation modes: Access point (up to 16 stations), station, Wi-Fi direct (combinations) Bluetooth 5.2 Dual-mode Bluetooth classic and Bluetooth Low Energy 5.2 LE Audio Output power EIRP – 20 dBM Bluetooth profiles and services – Bluetooth HCI 802.15.4 radio Supports Thread and Zigbee Support for the Matter protocol Variants with PCB-antenna, U.FL connectors, and antenna [...]
The post u-blox MAYA-W2 IoT module offers dual-band WiFi 6, Bluetooth LE 5.2, and Zigbee/Thread connectivity appeared first on CNX Software - Embedded Systems News.
View the full article
