[CNX-Software] - 5G RedCap leverages 5G features, limits bandwidth to 85Mbps for industrial IoT applications
5G Evolution 5G RedCap, LPWA, eMBB
5G is often associated with Gigabit speeds when found in mobile handsets or connected laptops, while there’s also 5G LPWA for battery-powered IoT devices. 5G RedCap, which stands for Reduced Capability, offers a middle ground for industrial IoT applications that keep some 5G features such as low latency, low power consumption, enhanced security, and network slicing while limiting the bandwidth to around 85 Mbps. 5G RedCap, also called NR Lite, will be part of 3GPP Release 17 scheduled for later in 2022, and further improved in Rel 18 in 2023. It will be first found in applications currently relying on LTE Cat 1 through Cat 4, and can be considered a light version of the 5G standard. An article on Telit says Rel 18 will specifically address the low-power wide-area network (LPWAN) segment currently carried seamlessly (e.g. no hardware changes required) in 5G by LTE-M and NB-IoT. I found out [...]
The post 5G RedCap leverages 5G features, limits bandwidth to 85Mbps for industrial IoT applications appeared first on CNX Software - Embedded Systems News.
View the full article
