[Pull Request] - WaveShare Touchscreen Driver Fix (Odroid) "disable_vu7"
Description
A number of other WaveShare screens also use ID: 0eef:0005 and therefore the patch used to enforce the VU7 driver breaks these other screens. This was the purpose of the "disable_vu7" env boot param which correctly defaults to true. However, this is ignored in boot.cmd + the patches for the kernel reverse the changes made by Hardkernel to fix this problem.
I have corrected the problem by removing 0eef:0005 from the driver enforced ignore_list and changed boot.cmd to allow the "disable_vu7" to function correctly (adding usbhid quirk when set to false).
How Has This Been Tested?
  • Ran build of current kernel (meson 5.10) to test that changes are working as expected. They are. Touchscreen now works and is attached to the usbhid driver.
  • Can not test functionality of VU7 (do not have VU7) however I have created this patch from the fixes applied by Hardkernel. When updating "disable_vu7"=false the screen does not function correctly (as before) and is assigned dwav_usb_mt driver implying the changes to boot.cmd work correctly.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
