[Pull Request] - update rockchip64-edge to 5.18
Description
Update kernel of rockchip64-edge to 5.18. Some wifi module failed to compile so I disable them (CONFIG_RTL8822CS, CONFIG_RTL8821CU, CONFIG_88XXAU)
Remove u-boot patch for rk35xx 0001-Lower-the-priority-of-EFI-to-be-after-DOS-partition.patch because I can't reproduce issue #3271 @catalinii described.
Regenerate patches of rk356x (for rock-3a) based on mainline (linux-next).
Copy all the other board patches from rockchip64-5.17 and modified some patches to make them successfully applied to kernel 5.18. Here are the details: 1, add-rockchip-iep-driver.patch modified since source tree change 2, general-emmc-hs400es-init-tweak.patch deleted since merged in 5.18 3, board-pbp-add-dp-alt-mode.patch modified since upstream file update 4, board-pbp-add-suspend.patch modified since upstream file update 5, add-csgpio-to-rockchip-spi.patch deleted since api change 6, board-firefly-rk3399-dts.patch modified since upstream update
Some other boards use rockchip64 family, but I only have rock3a on my hand. @armbian/board-maintainers have to test this kernel.
How Has This Been Tested?
  • [x] Patches are applied successfully
  • [x] Rock3A runs ok. @catalinii you can try this new kernel
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
