[CNX-Software] - DepthVista USB 3D ToF camera supports close range depth measurement, far-range object detection
DepthVista is a USB Time-of-Flight (ToF) camera designed for precise 3D depth measurement in close range mode (1.2m) and person and/or object detection in far-range mode up to 6 meters away. This ToF camera combines a 3D depth camera capable of 640 x 480 @ 30fps, and an Onsemi AR0234 color global shutter sensor supporting HD and FHD at up to 30fps, plus an 850nm VCSEL (vertical-cavity surface-emitting laser) for safety and the ability to operate in complete darkness. e-con Systems’ DepthVista (See3CAM_TOF_25CUG) specifications: Depth camera 3D camera technology: Time-of-Flight Depth range Near mode – 0.2m to 1.2m Far mode – 1m to 6m Illumination: 850nm pulsed laser (Indoor) Accuracy: Up to 1% depending on environmental conditions Output format: Y16 (raw 12-bit) Resolutions Depth – 640 x 480 @ 30fps IR – 640 x 480 @ 30fps Depth + IR – 640 x 960 @ 30fps FOV – 84.29° (H) [...]
The post DepthVista USB 3D ToF camera supports close range depth measurement, far-range object detection appeared first on CNX Software - Embedded Systems News.
View the full article
