[Pull Request] - add spi boot support for rock-3a
Description
In kernel 5.18 sfc is added to device tree: https://github.com/armbian/build/blob/master/patch/kernel/archive/rockchip64-5.18/rk356x-sfc-support.patch. So it is possiable to install u-boot to spi flash inside linux system. U-boot image generating commands is reffering to this radxa wiki page(also written by me). Now I can install u-boot to spi flash using command nand-sata-install, and my system on NVME boots with no issue. @catalinii you can test it if you have a NVME rootfs because sfc is the at the last boot order.
How Has This Been Tested?
  • [x] u-boot build successfully
  • [x] use nand-sata-install to install u-boot to spi flash and reboot with no issue
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
