[Pull Request] - fix rock3a UBOOT_TARGET_MAP
Description
Pull request #3838 add spi boot support for rock-3a. It can build successfully on my local machine, but build will fail in github workflow environment: https://github.com/amazingfate/armbian-rock3a-images/runs/6648716251?check_suite_focus=true#step:3. After this fix build is ok now: https://github.com/amazingfate/armbian-rock3a-images/runs/6649318129?check_suite_focus=true
How Has This Been Tested?
  • [x] Build sucessfully in github workflowwnvironment.
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
