[CNX-Software] - ARIES Embedded unveils OSM modules based on Renesas Arm or RISC-V microprocessor
Renesas-Arm-RISC-V-OSM-module.jpg?lossy=
In another case of “Arm or RISC-V? Why not both“, ARIES Embedded has introduced “MSRZG2UL” and “MSRZFive” OSM compliant system-in-packages (SIPs) based on respectively Renesas RZ/G2UL Arm Cortex-A55/Cortex-M33 and RZ/Five AX45MP RISC-V microprocessors and designed for industrial controllers, IoT devices, and embedded systems with a basic GUI. Both solder-on modules come in the OSM Size S form factor (30x30mm), 512MB to 4GB of DDR4 RAM, a 4GB eMMC NAND flash, various interfaces including Gigabit Ethernet and CAN-FD, and are available in either commercial (-0°C to +70°C) or industrial (-40°C to +85°C) temperature ranges. “MSRZG2UL” and “MSRZFive” specifications: SoC MSRZG2UL module – Renesas RZ/G2UL single-core Cortex-A55 processor @ up to 1GHz with Cortex-M33 real-time core @ up to 200MHz MSRZFive module – Renesas RZ/Five single-core RISC-V AX45MP processor @ to 1.0 GHz System Memory – 512MB – 4GB DDR4 RAM Storage – 4GB eMMC NAND Flash 332 contacts with Display I/F [...]
The post ARIES Embedded unveils OSM modules based on Renesas Arm or RISC-V microprocessor appeared first on CNX Software - Embedded Systems News.
View the full article
