[98]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[103]BOOT0 commit : 593cf83
[105]set pll start
[108]periph0 has been enabled
[111]set pll end
[113]unknow PMU
[115]PMU: AXP806
[122]vaild para:1  select dram para0
[125]board init ok
[127]DRAM BOOT DRIVE INFO: V0.52
[130]the chip id is 0x5000
[133]chip id check OK
[135]DRAM_VCC set to 1500 mv
[139]read_calibration error
[143]read_calibration error
[147]read_calibration error
[151]read_calibration error
[155]read_calibration error
[159]read_calibration error
[163]read_calibration error
[167]read_calibration error
[171]read_calibration error
[175]read_calibration error
[177]retraining final error
[182][AUTO DEBUG]32bit,1 ranks training success!
[189]DRAM CLK =720 MHZ
[192]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[198]Actual DRAM SIZE =1024 M
[201]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
[214]DRAM simple test OK.
[217]rtc standby flag is 0x0, super standby flag is 0x0
[222]dram size =1024
[224]*****dram handle ok****
[228]card no is 0
[229]sdcard 0 line count 4
[232][mmc]: mmc driver ver 2019-12-19 10:41
[236][mmc]: sdc0 spd mode error, 2
[240][mmc]: set f_max to 50M, set f_max_ddr to 25M
[245][mmc]: mmc 0 bias 0
[253][mmc]: Wrong media type 0x0
[256][mmc]: ***Try SD card 0***
[266][mmc]: HSSDR52/SDR25 4 bit
[269][mmc]: 50000000 Hz
[271][mmc]: 29819 MB
[273][mmc]: ***SD/MMC 0 init OK!!!***
[372]Loading boot-pkg Succeed(index=0).
[376]Entry_name        = u-boot
[385]Entry_name        = monitor
[389]Entry_name        = dtbo
[392]Entry_name        = dtb
[396]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):9fecd83
NOTICE:  BL3-1: Built : 17:08:29, 2020-05-28
NOTICE:  BL3-1 commit: 8
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-armbian (May 28 2022 - 09:09:02 +0000) Xunlong Software
[00.472]CPU:   Allwinner H616
[00.475]Model: Orange Pi Zero 2
I2C:   ready
[00.479]DRAM:  1 GiB
Relocation Offset is: 35ec7000
[00.520]secure enable bit: 0
[00.523]PMU: AXP806
[00.528]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.710]sunxi overlay merged okqv
[00.713]drv_disp_init
[00.742]__clk_enable: clk is null.
tv_init()950 fetch tv0 err.
[00.748]drv_disp_init finish
[00.750]gic: sec monitor mode
[00.756]flash init start
[00.758]workmode = 0,storage type = 1
[00.761]MMC:	 0
[00.762][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.769][mmc]: get sdc_type fail and use default host:tm1.
[00.779][mmc]: Using default timing para
[00.783][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.801][mmc]: card_caps:0x3000000a
[00.804][mmc]: host_caps:0x3000003f
[00.808]sunxi flash init ok
[00.811]Loading Environment from FAT...
[00.815][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.821][mmc]: get sdc_type fail and use default host:tm1.
[00.831][mmc]: Using default timing para
[00.835][mmc]: SUNXI SDMMC Controller Version:0x40200
** Bad device mmc 1 **
Failed (-5)
[00.846]usb burn from boot
delay time 0
weak:otg_phy_config
[00.859]usb prepare ok
[01.663]overtime
[01.667]do_burn_from_boot usb : no usb exist
[01.671]boot_gui_init:start
141 bytes read in 15 ms (8.8 KiB/s)
Set HDMI disp_mode to 1080p60
141 bytes read in 14 ms (9.8 KiB/s)
Set fb0_width to 1280
Set fb0_height to 720
[01.986]boot_gui_init:finish
[01.989]bmp_name=/boot/boot.bmp
230454 bytes read in 38 ms (5.8 MiB/s)
[02.041]update dts
Net:   [02.044]No ethernet found.
Hit any key to stop autoboot:  1  0
no mmc device at slot 1
[03.071][mmc]: card_caps:0x3000000a
[03.074][mmc]: host_caps:0x3000003f
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3202 bytes read in 18 ms (172.9 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
262144 bytes read in 45 ms (5.6 MiB/s)
** File not found /boot/dtb/allwinner/overlay/-fixup.scr **
6995211 bytes read in 610 ms (10.9 MiB/s)
** File not found /boot/Image **
Unknown command 'booti' - try 'help'
SCRIPT FAILED: continuing...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
armbian#
UART output trying to boot from 28/05/2022 images.
Posted (edited)
Workaround: Install https://armbian.systemonachip.net/archive/orangepizero2/archive/Armbian_22.02.2_Orangepizero2_bullseye_legacy_4.9.255.img.xz and put the 22.05 packages on hold before upgrade:
apt list --upgradable|fgrep 22.05| awk -F "/" '{print $1}' | xargs -n1 -i{} apt-mark hold {}
apt-unhold armbian-zsh
apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages have been kept back:
  armbian-bsp-cli-orangepizero2 armbian-config armbian-firmware linux-dtb-legacy-sun50iw9 linux-image-legacy-sun50iw9 linux-libc-dev linux-u-boot-orangepizero2-legacy
Edited by armbianorange2hero
Added URL for 22.02 image
