[CNX-Software] - STMicro VL53L8 multi-zone direct Time-of-Flight (dToF) sensor improves range and efficiency
STMicro VL53L8
STMicro VL53L8 multi-zone direct Time-of-Flight (dToF) sensor doubles the ranging performance of VL53L5 sensor – up to 4 meters – or reduces the power consumption by half when operating in common conditions. STMicro ToF sensors are some of the most popular devices to accurately measure distance in real-time, and the earlier VL53L0X and VL53L1X sensors integrated a single photon avalanche diode. STMicro VL53L5 changed that with multi-zone support (up to 64 zones), and VL53L8 FlightSense sensor builds on the solution with improvements in terms of range and efficiency. STMicro VL53L8 ToF sensor specifications: Low-power 32-bit microcontroller running the firmware 940 nm invisible Vertical Cavity Surface Emitting Laser (VCSEL) and integrated analog driver 61° diagonal square system field of view (FoV) using diffractive optical elements (DOE) on both transmitter and receiver Receiving array of single-photon avalanche diodes (SPADs) Parallel multi-zone output – Either 4×4 (16 zones @ 60 fps) or 8×8 [...]
The post STMicro VL53L8 multi-zone direct Time-of-Flight (dToF) sensor improves range and efficiency appeared first on CNX Software - Embedded Systems News.
View the full article
