RSS Bot Posted June 10, 2022 Posted June 10, 2022 Description As the issue @catalinii mentioned in #3271, when a sdcard has got flashed with radxa rock3a image or manjaro-arm rock3a image before, armbian can't boot on this sd card after flashed with ether. Here is the root cause: https://forum.armbian.com/topic/12352-orange-pi-4/page/3/#comment-94322. We can avoid this issue by using the same gpt partition type as radxa and manjaro, and use the same fat /boot partition to aviod the bad support for ext4 filesystem from rockchip legacy u-boot. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Prepare a sd card, flash it with radxa official image, and then flash the armbian image built before this commit, the sd card failed to boot. [x] Flash the sd card with armbian image built with this commit, system boots up successfully. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
