Description
@150balbes @paolosabatino @The-going if anyone finds time to check this.
(media:media:current:firefly-rk3399) (rockchip64:rockchip64:current:clockworkpi-a06) drivers/spi/spi-rockchip.c:767:12: error: redefinition of ‘rockchip_spi_setup’ make[2]: *** [scripts/Makefile.build:288: drivers/spi/spi-rockchip.o] Error 1 make[1]: *** [scripts/Makefile.build:550: drivers/spi] Error 2
(rk322x:rk322x:current:rk322x-box) (rockchip:rockchip:current:tinkerboard) make[4]: *** [scripts/Makefile.build:288: drivers/staging/media/rkvdec/rkvdec.o] Error 1 make[3]: *** [scripts/Makefile.build:551: drivers/staging/media/rkvdec] Error 2
(sunxi64:sunxi64:edge:bananapim64) (sunxi:sunxi:edge:bananapi) drivers/bluetooth/btrtl.c:891:11: error: ‘HCI_QUIRK_BROKEN_LOCAL_EXT_FTR_MAX_PAGE’ undeclared (first use in this function); did you mean ‘HCI_QUIRK_BROKEN_LOCAL_COMMANDS’?
Jira reference number [AR-9999]
How Has This Been Tested?
  • [ ] Test A
  • [ ] Test B
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
