[CNX-Software] - Fingerbot Sense Zigbee or Bluetooth LE button pusher adds touchless control (Crowdfunding)
Fingerbot Sense
When we first wrote about Fingerbot Bluetooth mechanical button pusher to add automation control to (dumb) home appliances over two years ago, I was not convinced about the solution. But it must have gained enough traction, as Adaprox has now launched a sensor version – the Fingerbot Sense – with either Zigbee or Bluetooth connectivity, plus a new touchless control function. It works just the same way as before, simply place the Fingerbot Sense on top of a physical button, and control it with your smartphone, a voice assistant like Amazon Alexa or Google Home, or with the new touchless control, simply wave your hand in front of the button without having to touch it. Fingerbot Sense specifications: Connectivity – Bluetooth LE 4.2 or Zigbee 3.0 Stall torque – 2.0 kgf.cm Maximum movement – 12 mm Optional Toolpack with short, medium, long straight arms, rocker arm, ring arm, cushion blocks [...]
The post Fingerbot Sense Zigbee or Bluetooth LE button pusher adds touchless control (Crowdfunding) appeared first on CNX Software - Embedded Systems News.
View the full article
