Ricardo Martin Mantelli Posted July 11, 2025 Posted July 11, 2025 hola a todos, logré descargar u flashear la imagen de armbian pero cuando quiero bootear desde la tarjeta microsd utilizando el boton reset solo obtengo el logotipo de amlogic titilando. Hay algun procedimiento que no esté realizando para activar el multi boot? Muchas gracias por su ayuda.! Hi everyone, I managed to download and flash the Armbian image, but when I try to boot from the microSD card using the reset button, I only get the flashing Amlogic logo. Is there some procedure I'm missing to enable multiboot? Thanks so much for your help! 0 Quote
radioarica Posted July 11, 2025 Posted July 11, 2025 (edited) Ricardo Martin Mantelli seria bueno saber que equipo estas usando, porque en mi caso con una MXQ 4K con Amlogic S805 me anduvo sin problemas. Edited July 11, 2025 by radioarica 0 Quote
s-petersen Posted July 11, 2025 Author Posted July 11, 2025 If you guys want Bionic, I can remove stretch, and link it. You should try to download stretch again, and try a different SD card before anything else. 0 Quote
Olivier Sikora Posted August 29, 2025 Posted August 29, 2025 On 7/12/2025 at 12:11 AM, s-petersen said: If you guys want Bionic, I can remove stretch, and link it. You should try to download stretch again, and try a different SD card before anything else. OH MY GOD YOU HAVE THAT TOO? can you please share it? i need that image, i can host it on google drive myself if someone would need it 0 Quote
s-petersen Posted August 29, 2025 Author Posted August 29, 2025 Did you download stretch already, before I remove it to put up Bionic? 0 Quote
