[Pull Request] - OrangePi 4 LTS: fix bluetooth, better sdcard stability
Description
Spreadtrum (sprd) bluetooth chip declares a feature (park link status) which does not work so the device fails the initialization. This PR adds a workaround and a quirk to avoid using such feature, letting the device being correctly initialized, moreover it should not interfere with other bluetooth chips as the orangepi original patch does.
Also sdcard bus pins receive an increased current strength to improve sdcard compatibility
How Has This Been Tested?
  • [ ] Current (v5.15) kernel deb packages built and installed on existing system
  • [ ] Edge (v5.18) kernel deb packages built and installed on existing system
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
