[CNX-Software] - Iono RP D16 industrial IO module features Raspberry Pi RP2040 MCU
Iono RP D16 industrial IO module Raspberry Pi RP2040
Sfera Labs has launched another Raspberry Pi RP2040-based hardware platform with the Iono RP D16 industrial IO module following the Exo Sense RP multi-sensor module we covered last month. The Iono RP D16 module provides sixteen digital 24V I/O lines, an RS-485 serial interface, a wide range 12-28V power supply input, and its DIN-rail case enables installation in electrical cabinets and automation control systems. Iono RP D16 specifications: MCU – Raspberry Pi RP2040 dual-core Arm Cortex-M0+ microcontroller @ 133MHz with 264kB on-chip SRAM Storage – 16MB SPI flash Inputs/Outputs via terminal blocks Up to 16x 24V 640mA outputs driven by high-side switches that can also be configured as push-pull drivers for high-speed switching (via MAX14912 chips) Up to 16x 24V IEC 61131-2 compliant current-sinking inputs (via MAX22190 chips) 4x TTL level I/Os (1-Wire, I2C, Wiegand support) Serial  –  RS-485 interface to the RP2040 serial lines via terminal block with electrostatic [...]
The post Iono RP D16 industrial IO module features Raspberry Pi RP2040 MCU appeared first on CNX Software - Embedded Systems News.
View the full article
