[Pull Request] - Bump crazy-max/ghaction-import-gpg from 3 to 5
Bumps crazy-max/ghaction-import-gpg from 3 to 5.
Release notes
Sourced from crazy-max/ghaction-import-gpg's releases.
v5.0.0
  • Node 16 as default runtime (#136)
    • This requires a minimum Actions Runner version of v2.285.0, which is by default available in GHES 3.4 or later.
v4.4.0
  • Use eslint prettier plugin (#132)
  • Bump openpgp from 5.2.0 to 5.2.1 (#131)
  • Bump minimist from 1.2.5 to 1.2.6 (#134)
  • Bump @​actions/exec from 1.1.0 to 1.1.1 (#133)
v4.3.0
  • Update dev dependencies and workflow (#130)
  • Fix error deleting keys with short key id (#129)
  • Bump openpgp from 5.1.0 to 5.2.0 (#128)
v4.2.0
  • Align default ttl with GitHub job run timeout (#126)
  • Delete key using primary key ID not subkey ID (#125)
  • Set passphrase only for the fingerprint being used (#123)
  • Bump openpgp from 5.0.0 to 5.1.0 (#116 #120)
  • Bump actions/github-script from 4 to 6 (#115 #121)
v4.1.0
  • Handle signing-only subkeys (#112)
  • Bump @​actions/core from 1.5.0 to 1.6.0 (#114)
  • Bump actions/github-script from 4 to 5 (#113)
  • Bump ansi-regex from 5.0.0 to 5.0.1 (#111)
  • Bump tmpl from 1.0.4 to 1.0.5 (#110)
v4.0.0
  • OpenPGP.js v5 (#78)
  • POSIX-compliant inputs names (#109)
    • Rename gpg-private-key input gpg_private_key
    • Rename git-config-global input git_config_global
    • Rename git-user-signingkey input git_user_signingkey
    • Rename git-commit-gpgsign input git_commit_gpgsign
    • Rename git-tag-gpgsign input git_tag_gpgsign
    • Rename git-push-gpgsign input git_push_gpgsign
    • Rename git-committer-name input git_committer_name
    • Rename git-committer-email input git_committer_email
  • Bump @​actions/core from 1.4.0 to 1.5.0 (#106)
v3.2.0
  • Add git-config-global input (#103)
  • Use built-in getExecOutput (#102)
  • Handle if-asked for git-push-gpgsign input (#100)
  • Use getBooleanInput (#101)
  • Bump @​actions/core from 1.2.7 to 1.4.0 (#97)
  • Bump @​actions/exec from 1.0.4 to 1.1.0 (#96)
  • Bump ws from 7.3.1 to 7.5.0 (#98)
... (truncated)
Changelog
Sourced from crazy-max/ghaction-import-gpg's changelog.
5.0.0 (2022/05/26)
4.4.0 (2022/04/24)
Commits
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
