[CNX-Software] - Revopoint MINI 3D scanner digitizes small objects with 0.02mm precision (Crowdfunding)
Revopoint Mini high-precision 3D scanner
Revopoint MINI is a 3D scanner using high-resolution blue light that’s designed for smaller objects such as figurines, coins, jewelry, etc… that require a higher level of detail achievable thanks to the promised 0.02mm precision. The 3D scanner follows last year’s Revopoint POP 2 color 3D scanner with 0.1mm accuracy for larger objects, and the main differences are the lack of color scanning and the higher resolution most suitable for smaller objects, but also possible for larger objects while holding the scanner with one hand.  It would just take longer since the MINI’s single capture range is 118 x 64mm, instead of 210 x 130mm for the POP 2. Revopoint MINI specifications: Technology – Dual camera blue light Single capture – Accuracy: up to 0.02mm, range/area: 118 x 64 mm Point distance – 0.05 mm Working distance – 100 to 200 mm Minimum scan volume – 10 x 10 x [...]
The post Revopoint MINI 3D scanner digitizes small objects with 0.02mm precision (Crowdfunding) appeared first on CNX Software - Embedded Systems News.
View the full article
