[Amrbian Configurator PR] - Bump actions/labeler from 3 to 4
Bumps actions/labeler from 3 to 4.
Release notes
Sourced from actions/labeler's releases.
v4.0.0
v3.1.0
Dependency upgrades, docs updates, and behind-the-scenes maintenance.
See the full list of changes since 3.0.2 here: https://github.com/actions/labeler/compare/v3.0.2...v3.1.0
Thanks to @​GisoBartels and @​Muhammed-Rahif for their contributions!
v3.0.2
No API changes, but lots of behind-the-scenes upgrades, mostly to internal dependencies, tooling, and surrounding infrastructure.
v3.0.1
No user-facing changes.
That said, there were more than enough behind-the-scenes changes to warrant a new release: https://github.com/actions/labeler/compare/v3.0.0...v3.0.1
Commits
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
