jaysonsantos Posted July 1, 2022 Posted July 1, 2022 Hey there, had anyone any success enabling PWM to control a PoE hat [1]? I tried a few overlays but no luck. ``` rock-3a-worker-1:overlay:# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false overlay_prefix=rk35xx fdtfile=rockchip/rk3568-rock-3a.dtb rootdev=UUID=f0751d3c-c5c2-4ced-a989-772c2ad130a4 rootfstype=ext4 overlays=w1-gpio i2c7 i2c8 extraboardargs=nvme_core.default_ps_max_latency_us=0 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ``` I also built mraa with the following: ``` IMRAA=ON FTDI4222=OFF BUILDCPP=ON BUILDTESTS=ON BUILDSWIG=ON USBPLAT=ON ONEWIRE=ON INSTALLTOOLS=ON BUILDSWIGPYTHON=ON \ bash -c "./scripts/run-cmake.sh && make -Cbuild install" ``` but it won't show anything on gpio or pwm ``` mraa-gpio list No Pins ``` Any other ideas there? [1] Pinout -> https://wiki.radxa.com/ROCKPI_23W_PoE_HAT 0 Quote
jaysonsantos Posted July 3, 2022 Author Posted July 3, 2022 I found the answer on radxa's forum [1] by amazingfate. In order to make it, you need to enable amazingfate's overlay and then control the pwm, which can be done like this: wget https://raw.githubusercontent.com/radxa/kernel/stable-4.19-rock3/arch/arm64/boot/dts/rockchip/overlay/rk3568-pwm8-m0-fan.dts armbian-add-overlay rk3568-pwm8-m0-fan.dts sudo cat > /etc/systemd/system/fan-control.service <<EOF [Service] RemainAfterExit=true ExecStart=bash -exc '\ echo 0 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/export || true; \ echo 10000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/period && \ echo 5000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/duty_cycle && \ echo normal > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/polarity && \ echo 1 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/enable' ExecStop=bash -exc 'echo 0 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/enable' [Install] WantedBy=multi-user.target EOF systemctl enable fan-control.service reboot # so the overlay gets applied and the service start [1] https://forum.radxa.com/t/armbian-for-rock-3a-unofficial-build-with-mainline-kernel/9434/45 0 Quote
oneofthemany Posted July 19, 2022 Posted July 19, 2022 (edited) On 7/3/2022 at 4:46 PM, jaysonsantos said: I found the answer on radxa's forum [1] by amazingfate. In order to make it, you need to enable amazingfate's overlay and then control the pwm, which can be done like this: wget https://raw.githubusercontent.com/radxa/kernel/stable-4.19-rock3/arch/arm64/boot/dts/rockchip/overlay/rk3568-pwm8-m0-fan.dts armbian-add-overlay rk3568-pwm8-m0-fan.dts sudo cat > /etc/systemd/system/fan-control.service <<EOF [Service] RemainAfterExit=true ExecStart=bash -exc '\ echo 0 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/export || true; \ echo 10000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/period && \ echo 5000 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/duty_cycle && \ echo normal > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/polarity && \ echo 1 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/enable' ExecStop=bash -exc 'echo 0 > /sys/devices/platform/fe6f0000.pwm/pwm/pwmchip*/pwm0/enable' [Install] WantedBy=multi-user.target EOF systemctl enable fan-control.service reboot # so the overlay gets applied and the service start [1] https://forum.radxa.com/t/armbian-for-rock-3a-unofficial-build-with-mainline-kernel/9434/45 You have missed out the replace active with default in the dts file Edited July 19, 2022 by oneofthemany found the issue and wanted to inform the author 0 Quote
