[Armbian build PR] - Bump ossf/scorecard-action from 1.1.1 to 1.1.2
Bumps ossf/scorecard-action from 1.1.1 to 1.1.2.
Release notes
Sourced from ossf/scorecard-action's releases.
v1.1.2
What's Changed
Full Changelog: https://github.com/ossf/scorecard-action/compare/v1.1.1...v1.1.2
Commits
  • ce330fd use GITHUB_TOKEN when repo_token is empty on PRs (#335)
  • 2e062bc Get repo info from REST API if event file is unavailable (#576)
  • 85bc05a :seedling: Bump github.com/sigstore/cosign from 1.8.0 to 1.9.0 (#331)
  • f8cb15a :seedling: Bump github/codeql-action from 2.1.11 to 2.1.12 (#339)
  • fe5d183 :seedling: Bump actions/cache from 3.0.2 to 3.0.4 (#393)
  • ed46015 :seedling: Bump debian from 06a93cb to f695745 (#536)
  • 5cc5d09 :seedling: Bump github.com/spf13/cobra from 1.4.0 to 1.5.0 (#523)
  • f470ef7 Get the Golang code in sync with Bash (#489)
  • 1ca6c49 :seedling: Bump debian from 06a93cb to 06a93cb (#432)
  • 66a8cbc :seedling: Bump github.com/ossf/scorecard/v4 from 4.3.1 to 4.4.0 (#454)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
