[Armbian build PR] - Bump igorjs/gh-actions-clean-workflow from 1 to 2
Bumps igorjs/gh-actions-clean-workflow from 1 to 2.
Release notes
Sourced from igorjs/gh-actions-clean-workflow's releases.
v2
What's Changed
New Contributors
Full Changelog: https://github.com/igorjs/gh-actions-clean-workflow/compare/v1...v2
Commits
  • e46a2b9 Merge pull request #40 from igorjs/fix/34-0-workflow-runs-to-be-deleted
  • c3a0700 chore(ci): update dist folder
  • 1d5e599 fix: improves input parameter parser
  • abc1233 chore: update check workflow to update the dist folder
  • a9e0dbb Merge pull request #39 from igorjs/dependabot/npm_and_yarn/jest-28.1.2
  • 4e1e59c chore(deps-dev): bump jest from 28.1.1 to 28.1.2
  • 6a45197 chore: add know issues to the README
  • 79998f7 Merge pull request #38 from igorjs/dependabot/npm_and_yarn/octokit/types-6.38.1
  • 718af42 chore(deps-dev): bump @​octokit/types from 6.34.0 to 6.38.1
  • 5273f88 Merge pull request #35 from igorjs/dependabot/npm_and_yarn/eslint-8.18.0
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
