RSS Bot Posted July 5, 2022 Posted July 5, 2022 Description as the RK3328 USB3 phy driver adaptation from legacy kernel is no longer needed or compatible with Mainline, remove it. 2 affected boards: Station M1 is no longer supported by the Rockchip64 kernel, remove it's specific patches OrangePi R1 LTS refers to the PHY driver-introduced node to control an LED. remove that node. How Has This Been Tested? Build tested Checklist: [X] My code follows the style guidelines of this project [X] I have performed a self-review of my own code [X] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [X] Any dependent changes have been merged and published in downstream modules View the full article
