[Armbian build PR] - rockchip64: switch orangepi 4/LTS to mainline USB3 Type-C controller driver
Description
Orange Pi 4 and Orange Pi 4 LTS were the last boards using staging USB3 Type-C controller.
This PR moves both of them to use mainline driver, so staging driver can be removed from patchset (as suggested by @Tonymac32 here: https://github.com/armbian/build/pull/3953#issuecomment-1172962963)
Most of the changes have been adapted upon the same nodes from tinkerboard 2 device tree and GPIOs have been adjusted.
Since both opi4 and opi4 LTS share the same hardware, I felt it could be useful to change on both boards. Probably if it works for my opi4 LTS also works for regular opi4; I will do my tests, if @piter75 wants to do private tests, in compatibility with his free time and will, I guess it is very welcome, but as long as the USB3 hardware is the same I guess mine would be enough.
As side note, this also fixes the "active" -> "default" pinctrl for pwm2 on edge kernel device tree (https://github.com/armbian/build/pull/3935)
Jira reference number AR-1256
How Has This Been Tested?
  • [ ] Build an image for Orange Pi 4 and test USB Type C functionality
  • [ ] Build an image for Orange Pi 4 LTS and test USB Type C functionality
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
