[Armbian build PR] - Fix bug in vagrant options handling
Description
When compiling using vagrant as build environment, the first option following vagrant is skipped.
./compile.sh vagrant foo bar In this example foo is skipped. This PR fix that bug.
How Has This Been Tested?
  • [X] An image was successfully built using vagrant as builder.
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
